Nothing wrong with that. I like it that way.
Thats fine, but the setting arent for "MAXIMUM PURE PERFORMANCE", they are more "LETS KEEP DOT HAPPY AND KEEP MPG LOW"
You are saying then that raising the front end will raise MPG?
What I am trying to say is that I have seen some variations of, "Ford spent a lot of money engineering the suspension to be perfect, why change anything and mess that up?" many times and it simply isn't true. Its designed to meet MANY needs. Simply changing it doesn't make it worse by default. Ford has to make concessions for various reasons.
DOT stipulates: "The maximum bumper height on all motor vehicles except multipurpose passenger vehicles is 28 inches for the front bumper and 30 inches for the rear bumper, measured from the road surface."
If they didn't have that, manufacturers could go crazy with lifts and anytime a truck rear ended a car they would go through the back window.
Aftermarket/enthusiasts aren't as tied to those rules.
Yes, rake affects gas mileage.
In a world where they are trying to squeak out every drop of gas with 10 speed trannys, auto start/stop, etc, it makes a difference.
Look at the Gen 1 raptor, you could level it stock with just an adjustment.
You you think a raptor leveled with preload collars (that don't affect static spring rate) and rear deavers (progressive) doesn't outperform a stock raptor simply because Ford would have done it themselves if it is so great is really misguided thinking.
I OP didn't present anything about gas mileage in his original post.
I have a Gen 1. Stock it's not level. For me that looks perfectly fine.
Your last paragraph is mi-guided. I never said that nor do I subscribe to that. Oh, and I have Deavers on my Gen1 to improve the ride, which they did.
You say level gets better gas mileage. If that is so, then Ford could have improved the MPG by leveling the truck with a thinner rear spring block. And that would be fine with me also. Easier to load and unload to/from the bed.
I'd like to see the data that level gets better MPG. For me, if that is so, Ford would have done it.
That is true. My main concern is really the ride quality.
I can see how getting rid of the blocks in the rear would be helpful. Collars or any other front end lifting device will surely push the control arms toward vertical and away from horizontal, subsequently transmitting more terrain feedback to the frame.
