Joseph7Camacho
Hi everyone I just finished an audio install on a 19 Raptor i tapped into the oem amp and pulled my signals from the outputs i had originally ran the signal through Audiocontrols Ac-Lgd so the amp could see some load as i had read that the factory system will distort higher end frequencies when the amp sees no load. Unfortunately i am still getting a ton of distortional higher volumes at higher frequencies. Is this just the B&O amp? should i just rip it out and run a zen A2B? Any help would be greatly appreciated.
just so you can have an Idea of what i have going on from the factory amp the outputs ( front, rear, and sub signal) go to three Ac-Lgd from there the signal is sent to LCQ-1 and from there to a my four channel and mono block. i ran zero gauge from the battery both power and ground to avoid any engine noise. the head unit is still 100% in tact.
