Kramer29163
I apologize beforehand, I'm not forum savvy in the least!
I'm pretty sure I messed up and I need your help. I've made the mistake of buying a salvage rear instead of rebuilding my own, now I'm running into issues.
I've got a rear differential out of a 2011 SVT that I'm swapping into my 2010 SVT that has an aftermarket brake setup (not a big brake kit) the issue I'm coming across is that the aftermarket brake rotors don't fit the newer model year rear. I was under the (likely wrong) assumption that everything would be a direct fit.
Can anyone help straighten me out on how to make this work or if it even will?
I don't have any issue of doing any minor wrenching but I'd be very hesitant to Crack the cover and dig into anything inside. So if it were to get to in depth I just need the info to forward on to a qualified mechanic.
Attached is a not so great picture of the salvage axle if it helps.
