Decals...Finally Ordered Them...Installation Help
mouldman1
Long Island, NY
So I finally go around to ordering the box and hood decals...my inclination is not to put them on myself and have some professional do them. Has anyone done them themselves? Tips, Tricks, Advice?
Would I take them to an Autobody place, tint guy, or a sign place?
Thanks Guys
JuggNuttz
chicago
i would think any body shop would be able to do it. im sure they see enough decal work and such, that it shouldnt be a big deal to them. or if you know of a place that does like the body wraps for advertisment, see if they could do it.
Fred
Richmond, VA
Thanks Guys
I would try a sign shop...or try it yourself...I did the vinyl on mine with the matte black 3m Avery...it takes a little patience and an extra set of hands helps...
Deinonychus
Jacksonville, FL
I watched a well know auto stripe guy here in town install my 2012 side bed graphics on my 2011. I would not consider trying it myself!
KaiserM715
Kaiser Söze
I used to be a heavy equipment mechanic. The way we applied really big decals was to spray the surface with SprayWay glass cleaner, which would allow the decal to slide as it was positioned. Then, use a squeegee to squeeze the glass cleaner out from under it. This makes it a lot easier to get the bubbles out from under it. One of the decals we did was over 10' long (front frame of a motor grader).
Here is an example on the rear engine cover:
FileServlet
pwjstruebig
NW Indiana
You could do it yourself but a sign guy would probably be your best bet. If you feel comfortable doing it yourself like Kaiser said soapy water in a spray bottle (windex) and a squeegee is needed if you want it to look good.
Swordjr24
Central Arkansas
I just put mine on the bed this weekend. Luckily I'm good friends with a guy that has a sign shop & he helped me do it. It's pretty tough & I'm glad I didn't do it myself. If you do decide to do it yourself don't use glass cleaner with ammonia because that takes the adhesive off that makes it stick to the truck. Good luck!
Dr_Pain
Louisiana
I would be to do it myself. I would definitely ask the vinyl shop or the "stealership" what products are safe with their decals. The big thing is to have a PERFECTLY clean surface to start with. The following are steps you need to follow.
1) Wash the truck and wet the surrounding area/floor down to get the dirt and grim off the truck, and to keep the dust from being kicked up.
2) Do not dry the truck (helps attracts and traps floating dusts)
3) CLAY BAR the hood or sides of the truck (removes all the embedded surface contaminant). I would go one step further as to Iron X the surface as part of my prep.
4) Then comes an important step.... Put some nitrile gloves (and keep them for the remainder of the process) and use IPA solution or CP Eraser to prep the surface (please use clean soft microfiber towels at this stage)
5) Use 3M painter's tape to mark specific landmarks outside the area you will put the decal on (as a reference marker to take measurements from and to line up your work). This is CRITICAL to make perfect if you want that decal to look perfect! You can redo this part until you have ABSOLUTE PERFECTION!. (I use a mm based tape measure and go OCD big time!) DO NOT depend on taking measurements off the plastic stuff. Put the 3M Painter's tape down and measure the hood and mark center (top and bottom) and take all remaining measurements from there. To get a straight tape line for future measurements tack one side down and stretch it tight and apply it down. Again you can apply and reapply as many time as you want to make it PERFECT (and be careful with paint because you have nothing protecting it at this stage)
6) After all your tape is down, another IPA or Eraser wipedown won't hurt.
7) The next important step is to CLEAN your decal to kill the static electricity cling and to remove oily residues etc..
****Then you are ready to apply your decal.*****
8) LIBERALLY spray the "recommended decal lube" for your application
9) Align and measure, and align and measure, and align and measure off your tape lines. At this stage you and make as much changes as you want.
10) Using a 3M squeegee (always use the right tools), start from the center and squeeze all the lube and air bubbles from the decal. Make sure your squeegee is new and clean otherwise it may introduce scratches in your decal or on your paint as you get to the edge of the decal
11) Most vinyl shop recommend that you use a heat gun or good hair dryer and heat up the decal to help the adhesion process.
12) I am not sure if it is the general recommendation but I wait at least 12 hrs and then put the paint sealant/glaze/wax (which ever you chose) back on the truck and treat the decal no different than the painted surface (but don't use a cheap OTC product that turns white... get the good stuff).
Moral of the story:
1) Prep is KEY
2) Use the right tools
3) Be proud of your accomplishments :)
P.S. Let me add that an extra pair of hands or 2 is VERY important!! (as it was pointed out in an earlier post)
P.P.S. I will reinforce the prior post on staying away from AMMONIA at all cost. And please do yourself a favor and avoid cross contamination by using a quasi clean old windex bottle. Spend the money and get a brand new bottle for cleaning, and for your lube.
Deinonychus
Jacksonville, FL
What do you think of 303 Aerospace Protectant for the Raptor vinyl graphics?
