What was the actual lift from stock using +3 and drop shackles? Was it a true 1” ?Limit straps aren’t needed. I have Deaver +3 with rpg drop shackles.
My understanding is that they are a bit stiffer to compensate for bed racks and gear.. probably from more arc..I'm scared to combine the +3 with the extended shackle because I dont want it any stiffer and I dont run anything in the bed..unless I tell deaver to make the +3 just for the height but keep the spring rate the same as the +2 I already have..but it's only an inch so I'll probably just try the 16" shock with the extended shackle on a rpg bed cage and get the 17" of travel rather than 18"
I think it’s your best interest to consult SVC. I’ve dealt with both companies and have had much better experiences with Svc! RPG and customer service is something they lack. I ordered Hiems for my gen1 rpg tie rods. They said the were shipped. Long story short it was months later they arrived and I already had traded my gen1 in on a gen2. I will never give them my business again.Yeah the shackle is where the travel gain comes from..complimented with longer shocks..thinking about pulling the trigger on that bed cage now with the 16x3.0 king 3 tube..rpg says with the +2 and there extended shackle should give 17" of travel
