Deaver +3 or +4 (Live Shock Reset on page 3)
RaptorVette
RaptorVette
Corpus Christi, TX
Alright everyone, I had the Eibachs and Deaver + 4 HD's and drop shackles installed today.
Before measurements:
Front - 40in
Rear - 40in (with jack, tools and tool box and Retax cover) No weight stock was 41.5
After measurements:
Front - 41.5in
Rear Driver side - 41.75in ( jack is on this side)
Rear Passenger side - 42in
As far as ride, it feels very close to stock, I'm really happy with the results. I'll post pics later, it looks pretty damn close to being level.
TurboTJ
Denver, CO
Front - 40in
After measurements:
Front - 41.5in
How much did the drop shackles decrease the rear height?
Do you notice the ride being rougher with the HD rear springs?
RaptorVette
RaptorVette
Corpus Christi, TX
I think the drop shackles bring it down around an inch. It might be a little stiffer in the rear, but with the Live Valve shocks it rides pretty good. I've had the +3 HD springs on my Gen 1 Raptor, NO drop shackles and over 300lbs in the bed. I think these rear springs will really shine on high speed offroad and carrying more weight or towing.
06HAOLE
Rhome, TX
I put on Deaver +3HD springs yesterday to complement my Eibach springs up front on my 2019 Supercab. I still have the RPG bump kit to install in the next few weeks.
Measurements with empty bed:
Front: 42” ground to fender
Rear: 44” ground to fender
On Offroad trips I run a SDHQ tire rack with 2 spare tires, Pro Eagle jack, and 2 fuel jugs.
I’m going to keep two tires in the bed for now and see if the rake decreases after a few weeks
IndianaRaptor
Indiana
Damn clean Scab ! Post some more pics of it if you would. I’ve got a 18’ scab with eibachs up front and looking to do rear springs here soon. How are you liking those Deaver +3 HD’s ? Is it a lot stiffer with a empty bed ? Was looking at + 3 or + 4 regular springs. I don’t think I would need the HD since I don’t tow anything big and all I carry on a daily basis is a bed cover and some tow straps
06HAOLE
Rhome, TX
These Deaver HDs made the truck a lot smoother to the point that my wife made comments about it. I carry a lot of weight on my offroad trips so I had to go with the HDs over the SDs. My only issue is the ride current height. I might add a 1” drop shackle to get the ride height where I want it. I should be level with my full camping load out and have a 1” rake when the truck is empty.
Here is a photo of how bad the truck was sagging on stock leafs.
DINOZR
Southeast
How many pounds you think you have to cause that level of sag?
Good info in this thread. Thanks for posting!
RaptorVette
RaptorVette
Corpus Christi, TX
Edit: I re-installed the stock shackles and shortly after this post and with the rear tires @ 34psi, the rear was still at 42inch from fender to the ground.
Front - 40in
After measurements:
Front - 41.5in
Sheeepdog18
Bay Area
With the Deaved+3 HD, The ride quality didn't suffer or too stiff when your bed is empty or light load? I am on the fence with that set up but I don't do heavy off road at all just some back road camping trips with a lot of camping gears and a RTT. 90% of the time the bed with have less then 60 lbs in it.
