Dash cam install with cellink neo!
Uf28denied
Staten Island,NY
Just a quick question! I don’t have a test light (probably buy one after work Friday) but as impatient as I am I figured I’d ask if anyone knows, if I’m using a fuse tap for acc power out of the pass side fuse panel, not having a moonroof there’s a 30 amp fuse in that slot, is it acc on only and can I tap that one for the cellink battery? Thanks in advance!
Rapster
Dallas, TX
Try using a cell phone charger or cig lighter with a power light. I used it to make a test light when installing fog lights. Take side contacts and run to negative pole, take point contact and connect to power test point. Don’t need to buy a light, just make one.
95,404
58,973
Kwazyace
