1.5” and never left pavement. What the heck did I buy….Yeah definitely not uncommon once lifted. BUT, I would like to play devils advocate for a sec. I’ve seen just as many stock ( all gens) with torn cv boots with little miles on the axles. Those look like only 1” collars. Not trying to start an argument here. I’m just ASSUMING here, but one with 1” collars and probably 99% on road miles would equal to the same abuse as the type of terrain and capabilities these trucks are designed/meant for in stock form . I think it comes down more to the quality of parts. The pandemic hit a lot of sectors for sourcing parts….
Will remove the collars before taking it in. I have a feeling they’ll blame the after market wheels and 37’s though.It’s not uncommon to see lifted trucks with CV axle boot damage; it’s not warrantable when the ride height has been altered. Your best bet is probably to order a replacement axle.
I would say high road miles and increased CV angle tends to be harder on the boot than low mileage off road and normal ride height. Any time I’ve had a boot get a hole in it off road it has been from getting stabbed with a stick or something and just random chance. Meanwhile if the bellows are rubbing due to ride height then any miles will wear a hole in it eventually.Yeah definitely not uncommon once lifted. BUT, I would like to play devils advocate for a sec. I’ve seen just as many stock ( all gens) with torn cv boots with little miles on the axles. Those look like only 1” collars. Not trying to start an argument here. I’m just ASSUMING here, but one with 1” collars and probably 99% on road miles would equal to the same abuse as the type of terrain and capabilities these trucks are designed/meant for in stock form . I think it comes down more to the quality of parts. The pandemic hit a lot of sectors for sourcing parts….
Is that wire/retainer rubbing on the boot? I’d imagine that could cause it to tear/wear through. Is there a slice/hole in the boot?Getting my oil changed (Valoline) and they noticed a leak near the cv.
Any experts on this?
Should I remove collars before taking it in?
