- Joined
- Jul 18, 2017
- Posts
- 2,963
- Reaction score
- 1,382
Our CrystaLux Auxiliary Switch/Upfitter Pigtail Extension Kit is the perfect accessory for trucks equipped with factory switch systems or even aftermarket switch systems. Our kit extends your existing switch wiring an additional 6" (which is useful on trucks with short auxiliary switch wires, like the Gen3 F150 Raptors). Not only does our kit extend your switch wiring but it also adds on a quick connect WeatherPack connector. This is useful if you change accessories or decide to change which switch controls your accessory later on.
Each pigtail utilizes 14 gauge wire along with weatherproof, heat shrinkable wire connectors to ensure a corrosion free installation. The 6 pigtails designed for the vehicle/switch panel side are numbered 1-6 to help identify the circuit.
Simply strip back the existing factory switch wiring and crimp on the CrystaLux pigtail. Then use a heat source (such as a heat gun) to shrink the wire connector down which will encapsulate the wire in a waterproof seal.
INCLUDES
INCLUDES
- 6x Female Extensions
- 6x Male Extensions
