Corsa 3" Stainless Steel Cat-Back Exhaust System with 5" Matte Black Tips for all 2017-2018 F-150 Raptors.
If you love your new 2017-2018 F-150 Raptor but wish it had a bit more edge to it, than this Corsa 3" Stainless Steel Cat-Back Exhaust System with 5" Matte Black Tips may be exactly what you need! Pick up your new aggressive exhaust system from CJ Pony Parts today!
Corsa Cat-Back Exhaust (14397BPC) Features and Benefits:
- Full 304 Stainless Steel Construction
- Dual Rear Exhaust Exit Design
- Dual 5" Pro-Series Matte Black Tips
- Includes All Necessary Hardware
- Flows 11.15% Better Over Stock Exhaust
- Almost 9 lbs. Lighter Than Stock Exhaust
- Custom Tuned for Aggressive Exhaust Noise
- Easy Bolt-On Installation
- Patented RSC Technology
- Aggressive Sound Under Acceleration
- Drone-free at Cruising Speeds
- Perfect Direct-Fit Upgrade From Stock Exhaust
If you're looking to increase power and save weight, Corsa's cat-back is able to provide both. With a 11.15% increase in flow over your F150 Raptor's stock exhaust, the Corsa cat-back is guaranteed to increase power. The entire cat-back system from Corsa weighs in 9 lbs. lighter than the factory exhaust which is a much need improvement for the big truck. This upgraded exhaust system is a direct-fit to your OE stock system and will be an easy bolt-on installation that doesn't require any welding. You'll love the loud, aggressive roar this larger system provides, and the dual 5" matte black tips will add a bit more style and personalization to the rear of your Raptor. Corsa takes pride in their premium-quality stainless steel construction, so you know it'll be durable enough to last for years to come. What are you waiting for? Order your upgraded cat-back from CJ's today!
Vehicle Fitment Note: This cat-back system will fit both SuperCrew and SuperCab 2017 and 2018 F-150 Raptors.
Corsa's exhaust systems are outfitted with their patented Reflective Sound Cancellation Technology. This technology was intended for an aggressive sound under acceleration and a drone-free occurrence during cruising. Every Corsa system is precisely designed for each application. Acoustic tuning hones and enriches the unique aggressive voice of your vehicle. Patented RSC technology terminates frequencies that cause unwelcome cabin drone. These unwelcome, low frequency sound waves are redirected through specifically designed channels and are reversed 180°. A state-of-the-art straight-through design boosts engine performance by reducing back pressure and increasing engine proficiency.
Order this aggressive Corsa 3" Stainless Steel Cat-Back Exhaust System (14397BPC) with 5" Matte Black Tips for your 2017 or 2018 F-150 Raptor today from CJ Pony Parts!
