Cobb FMIC installed. Lost reverse brake assist
braaptor37
Florida
Hello I installed a Cobb front mount intercooler and now my truck says reverse brake assist not available!
Any suggestions? It worked before I messed with it lol
Antho
How long have you been driving since you did the intercooler? Assuming you disconnected the battery? The system has to relearn steering center before it will work. So it may need a drive before it will start working. This is all assuming you havent been driving since the intercooler swap.
B
braaptor37
Florida
Did not disconnect battery, didn’t see that part in the instructions.
Drove 2 key cycles maybe 15 mile round trip.
Also the piping was a pia. Do you know the correct way the driver side goes? can’t figure that out either
hingedthinker
Phoenix
look up my thread and pics of the install. The driver side pipe was a pain, but only until I realized you needed to balance the overlap to make it work with the pipe clamps
ToadSmasher2K1
Home Is Where You Make It
KC
The rear brake assist is turned on and off through the vehicle settings on the main screen. It might be as simple as turning it back on?
I have mine turned off because it freaks out when I’m trying to back into my garage.
B
braaptor37
Florida
I don’t see it on settings?
