Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Lighting Modifications Forum [GEN 1]
Change Grill Lights to White LEDs?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="soundman98" data-source="post: 161963" data-attributes="member: 4543"><p>you can't change them easily. </p><p></p><p>according to my 2011 auto show closeup pics, there are about 2-4 led's and they are either plcc2 or plcc4 led's mounted to a white pcb. </p><p></p><p>they appear to be snap-fit to the truck, and between the installation method and the type of led's used, i would expect that it would be perma-sealed(like the headlights) so you would need to dremel the housings open just to gain access to the led's.</p><p></p><p>the second issue your going to run into is the difference in forward voltage-- red/yellow led's have a lower forward voltage then white or blue led's.</p><p></p><p>there is a possibility you could swap them(if the led's use a heatsink design, you better brush up on your hotplate skills-- that's going to be the only way to remove them) and they could just work, but it is unlikely--from fords led tails used on the mustang, i believe they would have a dedicated driver circuit that might not be very happy powering white led's. which means that you will need to custom build every 'pod' yourself, or find someone else that will do it for you..</p><p></p><p>so, time for you to stop by the led section at hidplanet.com so you can learn all of this <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite2" alt=";)" title="Wink ;)" loading="lazy" data-shortname=";)" /></p></blockquote><p></p>
[QUOTE="soundman98, post: 161963, member: 4543"] you can't change them easily. according to my 2011 auto show closeup pics, there are about 2-4 led's and they are either plcc2 or plcc4 led's mounted to a white pcb. they appear to be snap-fit to the truck, and between the installation method and the type of led's used, i would expect that it would be perma-sealed(like the headlights) so you would need to dremel the housings open just to gain access to the led's. the second issue your going to run into is the difference in forward voltage-- red/yellow led's have a lower forward voltage then white or blue led's. there is a possibility you could swap them(if the led's use a heatsink design, you better brush up on your hotplate skills-- that's going to be the only way to remove them) and they could just work, but it is unlikely--from fords led tails used on the mustang, i believe they would have a dedicated driver circuit that might not be very happy powering white led's. which means that you will need to custom build every 'pod' yourself, or find someone else that will do it for you.. so, time for you to stop by the led section at hidplanet.com so you can learn all of this ;) [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
physhy
tabvette
ranger22
Old-Raptor-guy
JerseyFR
elpechedepeche
PabstBleuRibbon
Traindodger
greatone99
QtrHorse
dj30417
NickyF25
DJgen3
MeFryRice
Bullet Bob
taquitos
full-race geoff
Rob O
ToadSmasher2K1
wyomingraptor
bradyp91
nikhsub1
berto2323
mwaite09
2025 Raptor
CleverGirl_
Keith88
Kenan
SDB666
Bozz
DAVfoto
Sozzy12
GiantSalmon
elking
KingKoopa17
OKflyswatter
n00dler
Willimiza
asgardthor44
RoNiN Raptor
steem430
jnall
03Cobraraptor
lucid_rap
Goose8651
RaptorsAreBirds
Clinton
birrclan
dvm
SonoranGen3
... and 31 more.
96,855
60,807
rfmitros
Forums
Accept
Learn more…
