MarkT
- Joined
- Mar 4, 2010
- Posts
- 1,202
- Reaction score
- 26
I finally got around to installing my CB antenna. (CB's are really nice to have while off roading.) Also, you can attach a buggy whip to the same mount if you are running the dunes...
I could not find a mounting system that I liked. So I decided to build my own our of odds and ends I had lying around.
From the research I've done, one of the best places to mount a CB antenna on a pickup truck is in the driver's side rear stake pocket.
First step was to remove the plastic bed rail cover. I started at the rear and carefully pulled up on the plastic. Once you get started, one row of clips can be easily reached from inside the bed under the lip of the rail. For the other clip, I used a little hook to pull one side of the clip towards me and a little screwdriver to push the other side of the clip away from me... once I got the hang of it, the entire bed rail cover was off in seconds. (Hint: use a little block or something under the rail cover as you release it so it doesn't reattach itself... )
Then I found an old antenna bracket. I decided to bolt it into the rear post hole. The only problem was the bed rail is not exactly square so I needed to bend the bracket slightly.
Pic showing the bracket and the slight bend:
Then I measured and drilled two holes to mount the bracket into the post hole:
The bracket installed in the post hole. (the bolts were later cut off flush with the nuts)
I measured the location of the antenna and drilled a hole in the plastic bed rail cover. I used a "unibit" to make the hole. Nothing makes a more perfect hole in plastic or thin metal. You can see the pilot hole in the following pic. Also note you can see one of the mounting clips near the top of the photo.
One last note. Before buttoning everything up... make sure the coax is connected securely and the antenna is not shorted!
Completed:
With antenna removed.... which will be most of the time:
Completed:
