Doing some research on bump stop kits and they all seem to be pretty comparable. Here is what I found on each website:
RPG-
• 3 times thicker than the stock frame
• Strengthens whole rear frame, not just the weak sections
• Big enough and Strong enough to run 4″ long airbumps to increase payloads and towing
• 100% Lifetime warranty on your frame support
• Able to run very little air pressure for smooth and controlled ride
• Double cross bolt design to eliminate inward frame movement
• Doesn’t interfere with aftermarket exhaust options
Rogue-
• 100% American Made
• 3D CAD Designed
• Allows for maximum up travel (+2" of travel over competitors)
• Allows for more mounting points to frame for maximum strength than any other Bump stop on the market!
• Strongest center cross beam 2"x 3" rectangle Frame Brace
• 12 Point hardware on frame brace
• Works for both Sprung Over & Under Applications & up to 37" Tires on stock bedsides
• Takes a King or Fox 2.5" Bump stop
SVC-
• X-treme Offroad Mode = Over 1.5" Extra Bump Travel
• Stock Offroad Mode
• Tow/Payload Mode
• Either Fox or King 2.5" Bump Stops
• Grade 8 Zinc Plated Hardware To Reduce Rust
• CNC Laser Cut and Bent For Precise Fit
• Designed To Taper With Factory Frame
• 100% Bolt On
• Works With All Exhaust Systems
My personal thoughts are:
I like that the SVC is adjustable but its seams that the same effect can be had by adding an Air bump extension pad. I think the Rogue brackets look to be the most heavy duty. I like that RPG specifically notes more detail about their kit and it's compatibility with longer bump stops and aftermarket springs and exhaust.
Anyone have any thing to add?
RPG-
Rogue-
• 3D CAD Designed
SVC-
• Tow/Payload Mode
• 100% Bolt On
