Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
My 2020 did not, unfortunately, come with the spray on bedliner. Which bed mat is recommended as the best fit for out Raptors? There are sooo many brands!
I have the Weather Tech floor may and like it. It is molded to the bed, comes up about 6 inches on the side. Works well for what I need. Especially in combination with the hard bed cover. Remember, you can still Line-X your bed at anytime and it will look brand new.
Thanks for the suggestion. Weather Tech isn't available yet for the 2020. I ordered my tonneau yesterday so I was thinking along the same lines...pairing the two should work well.
The Husky UltraGrip is probably my frontrunner right now. (Correct me if it shouldn't be, please.) Thanks for the suggestions and headlines. I appreciate it.
I have always had good results with the OEM rubber bed mats. I like to run one even when the bed is lined. They are grippier for when you are partially loaded. Unfortunately, I can't run one in my current truck due to the bed cage and jack mount situation.
