hh65flyer
Well it got almost all the way to 40 today so it was time...
I've had my truck for about month and a half and had yet to wash it. Hey, don't judge, I did pressure-wash all the mud off of it! That's the beauty of having a white truck, they really don't look that dirty (at least from a distance). Contrary to what many might think...
I used Adam's products almost exclusively and overall I'm pretty pleased with the results. I think the cold(er) temps may have affected some of the 'ease' of application but everything seemed to have worked as advertised. I can't say yet whether that is better than other stuff I have used...it's too soon to tell that.
So my process was to wash the wheels, tires and fenderwells first. I used the All-Purpose cleaner on everything other than the wheels themselves. For the wheels I used the Deep Wheel Cleaner. The DWC did not change colors like I've seen on the videos. I used the Fender Brush and Wheel Brush. Both worked well. I was particularly pleased to see how gentle the wheel brush was on the painted surface of the wheels.
What I didn't like was the amount of product I had to use, especially considering the expense. My 'Purple Stuff' cleaner does the same job as the AP and I buy it in gallon size and dilute it. I also had a hard time with the DWC coming out in more of a stream than a 'spray' Yes, I know there are two settings on the bottle and yes I was using the spray or 'misting' pattern. Even in this setting, however, the product seems to come out in more of a stream and I was forced to use more of it to get coverage. This is likely more of a design problem with the squirt bottle than the product itself. More on this problem later...
I then washed out my bucket and started everything fresh with warm water and utilizing a two-bucket system to wash the truck. The soap was great! Very sudsy and slippery. I should mention that I have one outside spigot plumbed for treated/softened water direct from our Culligan system. I use this for washing cars exclusively. No issues with the washing, grit guards, mitts, etc. Good stuff.
I then misted the entire truck with Detail Spray and started to hit it with the clay bar. I had left the bar inside so it would be somewhat pliable. I had a hard time with it though. It was difficult to get flattened out and folded, etc. I used more detail spray to lubricate and basically did the entire truck (painted surfaces, headlights, etc). I didn't really get a lot of debris on the clay, not nearly as much as I would have thought. The Detail Spray dried quite a bit necessitating the use of more product to keep things lubed-up. I ended up using almost 1/3 rd of a container on my truck.
After claying, I rinsed the entire vehicle and pulled out the H2O Guard & Gloss. I used the two double soft towels from my kit, one wet, the other dry. I really liked this product a lot. I sprayed one panel of the truck, wiped it with the wet towel and buffed it with the dry one. Beautiful results. I especially like that it's usable on all surfaces. The rubber trim, plastic moldings, glass, Raptor graphics...great! What i didn't like was the application (again). This product is pretty thick and would not 'mist' from the bottle. Instead, it came out in globs and streaks. Yes I did shake it thoroughly. Cold temps? IDK but it made me use more product than necessary. I used about a 1/4 of the bottle to do my truck.
Finally I used the Tire Shine to dress the tires. The best part of this product has to be the smell!! Banana pudding all the way!! Yummy. Unfortunately I had much the same problems with the Tire Shine as I did the G&G (only worse). It's relatively thick and I could not get a consistent spray pattern. I had globs and streaks and a great deal of the product got on to the wheels. I used way more product than necessary to get the coverage I needed. I let it sit on the tires for a while then used a cotton towel to rub the Tire Shine into the tire. I have some fairly aggressive tires (Duratracs) so it took some effort to get it worked into all the gaps. I then had to wipe down my wheels (again) to get all the over-spray off. I used the wet towel with G&G still on it to do the majority of work then buffed with the dry towel. Probably used 1/3 of Tire Shine bottle to do four tires, outside only.
Overall I am pleased with the products although expensive for the results I achieved. At this point I don't believe I will buy more All Purpose or Tire Shine. I like the soap a lot and the H2O G&G worked great. Also, the equip was great...the brushes, towels, grit guards, etc. I've never really had dedicated detail stuff so this is a bonus.
I believe I followed all the directions and even watched several videos before doing the job so if I did something wrong...well I'm sure Dan will let me know!
Pictures below...
Pictures below...
