BAK Premium Matte BAKFlip MX4 Hard Folding Cover for all 2015, 2016 and 2017 F-150s with a 5' 6" Bed.
In this video, Bill & the crew at CJ's will show you how to install this BAK Premium Matte BAKFlip MX4 Hard Folding Cover on your 2015-2017 F-150 with a 5' 6" Bed from the comfort of your own shop or garage!
Showcasing premium quality aluminum matte finish, this UV and scratch resistant cover is built to last. This is the ideal solution for creating a more complete feel for your truck, adding an impressive amount of shielded storage space. Easily folding back to offer several options of usage, this top-of-the-line cover from BAK is designed to perform with excellence. Meeting the needs of any driver's demands, this cover can easily be adapted to fit the task.
Features & Benefits:
- Heavy-Duty Aluminum Matte Finish: UV and Scratch Resistant
- Made Out of Light but Durable Aircraft-Grade Aluminum
- Upgraded Injection-Molded Latch Housing Components for Added Durability
- Automatic Latching Panels
- Outer Rail Seals Made of EPDM Rubber for Maximum Water Resistance
- Enhanced Premium Density Foam Core
- Designed for Everyday Use in Extreme Conditions: Stands Up to Rain, Snow, Sun and More
- Easy to Operate from Either Side of Your F-150 and Allows for 100% Truck Bed Access
- Secure Place to Store Items to Prevent Theft
- Integrated Tailgate Seal: Tailgate Can Close with the Cover Up or Down
- Flush Mount: Built to Fit Inside Your F-150 for a Stylish, Sleek and Low-Profile Look
- Rated for Up to 400 lbs. of Evenly Distributed Weight
- 3rd Brake Light Visibility
- Easy Installation: No Drilling or Modifications Needed
- Integrated Buckle System Secures Cover in Folded Position: No Need for Straps or Bungee Cords
- Prop Rods Secure Cover in Flipped Up Position: 100% Unobstructed Bed Access
- Easy to Care for and Clean
- Made in the USA
- BAKBox 2 Compatible
- Upgrade from the G2 Series
Order a BAK 448329 Premium Matte BAKFlip MX4 Hard Folding Cover for your 2015, 2016 or 2017 F-150 with a 5' 6" Bed from CJ Pony Parts today!
- Made in the USA
