melvimbe
Before I say anything else, yes, I'm an idiot. The pole is located at the end of a friend's driveway, a house I'd never been at before. The driveway is mostly straight, except for a slight curve to the right at the street...because of the pole. So if you back straight out, you hit the pole. Yes, the collision sensor went off. The rear view camera was useless since it was raining. Did a quick visual check and didn't see anything. Since I've gotten false positives from the sensor before, and saw no reason for there to be any obstructions, I proceeded to back out.
Damage appears to be minimal. The driver's side of the rear bumper was pushed in slightly, maybe a half inch. No visible marks on the bumper. Not sure if the bumper was damaged or a bracket behind the bumper. About a week or two later, I noticed in crack in the driver's side tail light. Very small, even hard to find when you're looking for it. But yesterday, I noticed that there's moisture in the tail light.
So my questions are...do I need to be worried about the tail light? Will the moisture cause a short or additional damage, or should I just leave it alone until the light goes out? I'd obviously rather not replace the light if I don't have to.
Although I'm less worried on the bumper, and realize I get a complete answer here, but what's the likely damage? I tend to think the mounting bracket ($50) would need to be replaced, but could it be the bumper ($390) or reinforcement ($500)? I suppose I just need to take it to a body shop to get an actual estimate.
https://www.tascaparts.com/auto-par...gine/body-cat/bumper-and-components-rear-scat
