I don’t think this means what you think it means...
Inconceivable!
In both the R/A trucks and 802A trucks, in “Auto” / normal mode, the gears 1-10 are displayed on the dash, by default. Unless you fat thumb the shifter handle and accidentally toggle up or down, in which case the gear display disappears.
OK. I assumed that it defaulted to no gear numbers shown because when I first got in my 802A Raptor (as far as I know never driven, other than on and off the transporter) it had no gear numbers shown until I hit the up lever, then 1-10 showed up. And then when I got a new 2018 F150 XLT (350 miles on it when assigned to me, so lots of people had messed with it) at work it was the same way, no gear numbers showing until I hit the Up button.
But I suppose in both cases it is entirely possible someone else had hit the up button / paddle before I got in the vehicle. I could read the manual, but what is the fun of that?
Regardless, hit the up button or paddle and the numbers disappear, and stay that way until you hit Up (or Down) again. The vehicle starts in the same condition as you last left it.
That deselection you’re describing is called gear lock out. This is how the paddles work with the transmission in drive.
The gear display changes when you select manual mode on the shifter - it’s one position to the rear of drive. In this mode, you have to upshift by button or paddle, and you should downshift as well for proper thrust when you need it but the truck will downshift for you if you’re going too slow like slowing for a light.
Yes, in Auto it (down paddle or button) deselects gears, from the top down. So in Drive / Auto if I hit the down paddle twice it “shuts off” gears 9 and 10, resulting in only 1-8 being available for the system to use. I thought that was what I described. But hey, English is a second language for me, my first being Hick.
T!
---------- Post added at 10:03 AM ---------- Previous post was at 09:58 AM ----------
No. You can still shift into it and back out. All the other modes seem to work as before.
Do the backup and cross traffic sensors still work?
T!
