After reading GJMcManus' thread about the coolant leak he experienced due to a faulty hose clamp, I opened the hood of my two-week-old Raptor and sure enough, there is some spilled coolant near the top of the radiator, on the top corner of the air filter housing and a few other spots. A flashlight revealed some dripage down the side of the radiator and on the underside of the skip plate as well. None has actually leaked out onto the ground yet. I noticed the coolant resavoir is over-filled by about a quarter of an inch with the engine cold. I can't tell for sure where its coming from, but the hose clamp appears to be fine. So you 2012 owners might want to check under the hood as this could be common issue.
