If you got that as a rental, would you show people....Uranus?
Without doubt.
When you have multiple codes like that usually the first code that comes up is associated to the module taking out the whole network. The other cause is loose wiring on one of the connectors or even broken ones. Have to be on the look out for mice when it gets cold out. They should be able to view the network activity with a scope and wiggle some stuff around to see when it drops. It can be a tough job but shouldn't take days.
Multiple codes like what?
Do you think the dealer that told the op that there was a "network " problem could read codes with ids? Don't you think they would tell him before coming up with a story like that. And btw all sorts of codes coming up from everywhere is usually ecu failure.When you have multiple lights coming on and loss of control to certain things in the vehicle there will be multiple codes generated for all the failures in various modules. Even the power windows and locks have a module in each door that controls that function, they all talk on the same network and all generate failure codes. These codes cannot also be read on a normal OBD2 scanner but Forscan can probably read them. When you have a network or electrical failure a bunch of codes will generate for each module but finding the wire or module pulling down the whole network is tricky. These devices are all connected together in a loop, they are not isolated like normal Ethernet networks. Finding the module or wiring effecting these systems is a pain in the ass. But you usually start with the module that threw the first code in the list for good practice.
No, I don't think a shop is going to list all the codes for the customer, yes they can either read them or they can read nothing. Also multiple codes is not always ECU failure, ECU failure is actually pretty rare.
