Another 'too wide' thread
The Brit
Woodinville, WA (nr. Seattle)
After doing the middle perch, took my truck to Omni to get it aligned. Too wide for the alignment rack and they do all kinds of HD trucks. Went next door to Ford - the tech said, we'd take it to Omni! So he said it'd fit on the dealers rack but they don't have the latest software for the 2012 Raptor. Pretty nice of them not to BS me and just try and do it with F150 specs.
Turns out Les Schwab can fit it on the rack so I'll be back out there tomorrow to try again...
matt33
NE PA
The Raptor is a thick bitch. I saw an interview where SVT's lead engineer talked about how Ford stretched the track width as far as the could with the tooling available at the plant in MI. Any wider and they couldn't have built it in production #'s.
Hockster
My 45ft Bluewater Party
Winchester, Va
To Wide??? The turn plates are movable . Odd, they must be able to drive a dually on the rack and since the plates are movable you slide the front ones out to sit under the tires after you lift the truck... Hmm, strange
T
The Brit
The alignment shop has a pit where the front wheel alignment plates reside. The 2 foot long 'bridge' to the plates was too narrow, each tire would have been hanging off by half a tire width while the plates were set out to the maximum width. They did not want to risk the truck falling in the pit so opted not to attempt it.
Hockster
Winchester, Va
Ok, a bit more understood now. :)
BIRDMAN
Birdministrator
Boston
just get the specs and tell them to align it. what do they need software for?
