Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford Raptor Engine Discussion and Performance Mods
Ambient Air Regulating Boost?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="COBB Tuning" data-source="post: 1590858" data-attributes="member: 30143"><p>Ambient conditions will change target boost pressure in a few different ways - through charge air temperature (post intercooler air temp.), intake air temperature (pre turbo air temp.), barometric pressure, and the torque model. </p><p></p><p>At high charge air temperatures, target load will be decreased which will also decrease your boost pressure target. Also, when intake air temperatures are very high, an airflow-based limit can decrease target load and boost pressure. At low barometric pressure, a baro.-based compensation will decrease airflow limits and target load to keep the shaft speed of the turbo in-check, since lower baro. pressure will result in lower compressor inlet pressure. Without lowering boost targets with significantly lower compressor inlet pressure, the pressure ratio across the compressor will increase significantly along with turbo shaft speed. All of these limit features are in the factory calibration and are maintained in our OTS calibrations.</p><p></p><p>In cold conditions, charge air temperature based timing compensations will increase ignition timing. When this happens, the torque model can reduce target boost pressure to make sure that torque and power output remain consistent and safe. I doubt that ignition timing would be advanced enough in 30-40*F ambient such that the torque model was capping boost pressure to 12 PSI, so I would agree that you most likely have/had a boost leak.</p><p></p><p>Two other things to consider - 1) if you were in 2WD, traction control could have been cutting in and closing the throttle to stop wheel slip. As you might expect, this will significantly cut down on boost pressure. 2) boost pressure targets are not constant through the rev range. Our OTS, like many other calibrations, runs a pretty steep taper of boost pressure towards redline. So if you were only going WOT at higher RPM, you wouldn't see the same peak boost pressure on the Accessport gauge screen min/max values as you would if you did a pull through the entire rev range.</p><p></p><p>If you want any more help diagnosing the issue, feel free to send in a datalog of a 4th gear pull from 2500RPM to redline to <a href="mailto:support@cobbtuning.com">support@cobbtuning.com</a>. Make sure that you're using the default datalogging list. We can take a peek and see if we can offer any more specific advice.</p><p></p><p>-Sam@COBB</p></blockquote><p></p>
[QUOTE="COBB Tuning, post: 1590858, member: 30143"] Ambient conditions will change target boost pressure in a few different ways - through charge air temperature (post intercooler air temp.), intake air temperature (pre turbo air temp.), barometric pressure, and the torque model. At high charge air temperatures, target load will be decreased which will also decrease your boost pressure target. Also, when intake air temperatures are very high, an airflow-based limit can decrease target load and boost pressure. At low barometric pressure, a baro.-based compensation will decrease airflow limits and target load to keep the shaft speed of the turbo in-check, since lower baro. pressure will result in lower compressor inlet pressure. Without lowering boost targets with significantly lower compressor inlet pressure, the pressure ratio across the compressor will increase significantly along with turbo shaft speed. All of these limit features are in the factory calibration and are maintained in our OTS calibrations. In cold conditions, charge air temperature based timing compensations will increase ignition timing. When this happens, the torque model can reduce target boost pressure to make sure that torque and power output remain consistent and safe. I doubt that ignition timing would be advanced enough in 30-40*F ambient such that the torque model was capping boost pressure to 12 PSI, so I would agree that you most likely have/had a boost leak. Two other things to consider - 1) if you were in 2WD, traction control could have been cutting in and closing the throttle to stop wheel slip. As you might expect, this will significantly cut down on boost pressure. 2) boost pressure targets are not constant through the rev range. Our OTS, like many other calibrations, runs a pretty steep taper of boost pressure towards redline. So if you were only going WOT at higher RPM, you wouldn't see the same peak boost pressure on the Accessport gauge screen min/max values as you would if you did a pull through the entire rev range. If you want any more help diagnosing the issue, feel free to send in a datalog of a 4th gear pull from 2500RPM to redline to [email]support@cobbtuning.com[/email]. Make sure that you're using the default datalogging list. We can take a peek and see if we can offer any more specific advice. -Sam@COBB [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
moog5050
3Dog
SonoranGen3
P4SHOCAT
FGHT ON
GordoJay
IMFletcher
Reaper308
JohnyPython
Barr993
DMDRaptor
shank_guru
Space Ghost
MotorsportsAustin
bbohannon
taquitos
dinocrisis
FoShizzle
tm965
Keith88
Irregular F150
RoNiN Raptor
MurderedOutSVT
npc
pat247
stevenstommyboy1
Fireimp141
Frogger22
Shane361
Ox3721
FreightTerrain
Finlay150
jfrazier1212
MORaptor1
CADIMAX
xrocket21
jeffrey bush
zefen
pb510
rfranklin1
jwt8206
Canuck714
brian007
chenner
birrclan
Hard R
stumpyid
Sozzy12
Sandfreak520
Dnovakovic4
... and 12 more.
96,856
60,809
hazardsyd
Forums
Accept
Learn more…
