Yeah, I like the Boostane Professional as it works reasonably well, but as Goose said, do not run it often. It is a mosh-mash of chemicals and does bad things to the fuel system & plugs.
I strongly recommend an E50 tune, or even E30, that you can run all the time and actually keep things cleaner and running better than straight gasoline of any octane/brand. Ethanol will definitely make more power than the Boostane. I’ve run it and compared it to E50 and it’s much less effective. I had to turn the timing way down from E50 to run it at best power without a lot of knock events.
