50k tune-up
WarSurfer
DC
I started having intermittent ignition breakdown like bad plugs or a failing coil so I bit the bullet and dropped it off at my dealer for new plugs and coils.
I was not prepared for the prison **** that followed... $3,200 for a tune-up and one bad o2 sensor. The plugs alone were $600.
I will say though I had no idea just how bad it was performing power wise. Much better now.
Mariner
Lakeland, FL
Holy shit. I can say I'll be replacing my own plugs and coils when the time comes... so sorry you had to endure that brother
Sent from my SAMSUNG-SM-G900A using Tapatalk
Deleted member 12951
Guest
The dealer contacted you with that price before they started work, right?
Wideglide93
Indianapolis,IN
Just did a quick search and the 5.4 had problems with breaking the plugs off in the head adding additional labor. Any body know if the 6.2 had the same problems?
SilentShooter
Siesta Key, FL
WOW.... They use plugs made out of actual platinum
---------- Post added at 08:35 PM ---------- Previous post was at 08:34 PM ----------
No.. that was the original 3v head design and plugs. They changed to a new design for the 3v and resolved it. The 6.2l is a 2v setup
WyoStorm
Wyoming
How many hours?
WarSurfer
WarSurfer
DC
Yes.
They said the plugs closest to the firewall are labor intensive. Also, there is a plug behind the dual upper coil/shock mount on each side that they had trouble with.
I'm sure they got over on me but I'm not in any condition to be climbing around the engine compartment.
Two tune ups and I could have a supercharger, lol.
---------- Post added at 10:01 PM ---------- Previous post was at 09:53 PM ----------
How many hours?
Looks like almost 9hrs
1148 labor
1811 parts
63 disposal
108 tax
I forgot they also fixed my fuel door, it was like $100 for parts and labor. The rubber strap thing broke.
WyoStorm
Wyoming
Crazy! I know labor is pricey but 9 hours to do this at $125+/hour. And at my dealer, I brought my Escape in because it was idling very low and I had bought new arms for the back window that I wanted them to just install. I came back after work to pick it up and pay and they said a clip had come loose on the vacuum line and that there was no charge. I said what about the install. He said nope you're good to go.
Sent from my SM-G900V using Tapatalk
