40" and 30" light bar on switch #1?
BigBOSS
Austin, TX
Gotcha. Great news. So to be safe should I use 13.8 volts when calculating amp draw or is 14.4 going to be safe? I ask because I want to run a 5 watt 40" bar on Aux 1.
13.8 in the equation just gives you more room for error so if it's below the rated amps for aux1 you'd be fine
Sent from my SAMSUNG-SGH-I337 using Tapatalk
---------- Post added at 12:30 PM ---------- Previous post was at 12:26 PM ----------
I just like a buffer so as to not accidentally fry something. Or like I said earlier, just use a relay if it's close.
Nick@Apollo-Optics
So by run it on a relay, you mean use a separate switch? Or run a positive wire from the relay and tie that wire into the Aux 1 switch?
