Dane
I have the Recon one. So far it has worked fine. Couple things though, the instructions are worthless. Throw them away, they are flat out wrong, missing a wire, etc. I used a voltmeter to figure it all out. You do have to cut and splice - no plug and play. The fit seems weird, but I siliconed it all, and it seems fine. It's a very different looking light though. It's far from stock. I'm sure some like it, and some might not, but it doesn't have those three lights - it has a different almost icon type thing, then a different brake light, and LED cargo lights.There are a lot of cheap recon/ amazon options for less than 100 but do to plug in the same and I've heard mixed reviews from most of them. The stock part is about 90/ and for less than 200 you could have a stock set up with better cargo/ break lights - the other updated one from above has LED's, stock part, but not sure why more people haven't just updated ? Rock auto is cheaper than the Tasca below
https://www.tascaparts.com/oem-parts/ford-high-mount-lamp-al3z13a613g/?c=Zz1lbGVjdHJpY2FsJnM9aGlnaC1tb3VudGVkLXN0b3AtbGFtcCZpPU1BMDk5NTU1JnI9MSZhPWZvcmQmbz1mLTE1MCZ5PTIwMTAmdD1zdnQtcmFwdG9yJmU9Ni0ybC12OC1nYXM=
