37PP Tire ? Rubbing?
mgordon
Ventura,CA
I have a stock 2023 37PP with 17x8.5" O Offset Innov8 Wheels. Looking to swap my BFG for Toyo or Nitto. They both run true to size vs BFG as everyone knows. Has anyone done this upgrade & experienced rubbing? I do not have collars, top hat or springs. Hoping I don't need to run any suspension upgrades....for now. Thank you..!
MFouts
EW
If you are currently running those wheels with the stock 37" tire and you have no issues, I can't imagine that it would cause a problem with Toyo or Nitto. Looking at published dimensions it is less than an inch difference. I may be missing something though.
k3k0a808
Hawaii
I have Method 704's 0 offset rims with 37x12.5 Nitto Ridge Grapplers, I only rubbed once when I was going down a steep driveway all the weight was on that one tire, and my tires were turned, someone came speeding down the street so I had to brake hard. Rubbing was really minor
