"Gear hunts". I assume this means it constantly changes gears try to and find the correct one. Does this happen around town, on the freeway or both? And can one elaborate on "the towing experience isn't near as good"?Both will squat the same as they have the identical springs in the rear. Bumpstops will kick in slightly earlier on a 37 but you shouldn't be hitting those towing unless huge dips. As mentioned, gear ratios will be noticeably better on a 35. I have a 35 truck that tows a UTV and 6,500lb camper and I recently succumbed to trying 37's and it gear hunts significantly more and the towing experience isn't near as good.
