35" Mastercraft MXT Owners
Sitdown
Suburbia, IL
Anyone with the 35x12.5x17's weigh these themselves?
Also, couldn't find any info on sidewall plys, 2 or 3?
The weight i'm finding for these are 64lbs... just find this hard to believe given its a 10ply E load tire. If it is accurate, excellent
Any info on sizing compared to another tire for reference would be great, pics measurements etc... Not many sources out there to pull info from for these.
Barge
I've got one that's slightly used out in the shed I could probably measure and weigh with probably not the greatest of accuracy.
What measurements are you looking for?
Sitdown
Sitdown
Suburbia, IL
That would be great, mostly curious of weight as size info is avail on their site. To confirm, Do you have the 35x12.5x17 or 315/70R17?
Also can anyone confirm if tread & sidewall ply? I'm assuming the E load 35 is 10, and D load 315 is 8... So confirmation here would be great as well. I believe i read the 37 D load is 8 ply with 2 ply sidewall.
Thanks, data from mastercraft/cooper below
Tire Size Service Description UTQG Load Range Sidewall Approved Rim Width Measured Rim Width Section Width Overall Diameter Tread Width Max Load Tread Depth (1/32")
35X12.50R17LT 121Q E OWL 8.5 - 11 10 12.7 34.76 9.8 3195 20.5
LT315/70R17 121\118Q D OWL 8 - 11 9.5 12.8 34.49 10 3195 19.5
Pacific Wheel
Reno, NV
I show 67lbs on the 35 and 62lbs on the 315. Those were the recorded weights when these tires were shipped to us via fedex.
Cant help you on the height though. We only stock wheels.
Sitdown
Sitdown
Suburbia, IL
Thanks for the update, great info. Anything in your system on tread and sidewall plys?
Sitdown
Sitdown
Suburbia, IL
Decided to take the plunge and see if these would knock the Toyo MTs from my holy grail tire podium... Sadly, in the 3 months these sat on my patio, i never put them on a scale to find the # i so desperately sought to learn :facepalm:
DiscTire guy loaded these with 64lbs :Insane:, but i'd expect a lil a bit more bulge than shown. They are the 35x12.5x17 E load Tires, not the 315 ones.
Jimbo
Mad Frog Mattis
IL
Looks great, Tom!
