TerribleONE
Thanks for all the feedback and reviews they definitely helped me make a decision. What are you guys paying for the fronts? Any deals out there?
Hit up Apollo Optics. They took good care of me.
Anyone running "soft" for on road? "stiff" ? would love some feedback.
I ave been in the medium setting since installing them but did try "soft" for a quick drive home and it felt a bit too soft for my liking.
Are the 2019+ rear 3.0 live valves as noisy as the non live valve version? It looks like the 3.0 live valve is an internal bypass and the non live valve is external. I don’t like the clicking all that much from external bypass shocks.
My brothers off-road shop has Ford program. Takes 5 minutes tops. Just did eibach and icon leafs. Just tell them to do ride height calibration. In forscan you can see how far the shocks are off. Mine was like 39mm and now 1mm. Definitely a good idea to do again after 5k after springs settleIf you have Icon UCAs, then your system is different. You can check out the detailed install instructions, which talk about setting the live valve sensors using Icon's bracket system: https://images.iconfigurators.app/pdf/Icon_Dynamics/I98562DJ_REVB.pdf
I bet you can get it pretty close with the Icon brackets and doing the measurements, but you can get it exactly right by asking the Ford tech to set ride height to zero ;o).
The Ford invoice says: Confirmed customer concern. Had to reset tire pressures and TPMS. Confirmed check list for ride height parameters. Reset height level to zero.
They charged me 0.8 hour, but I had low tire pressures and my truck was dirty
How much pre load do you have?Watching the video at about the 3:45 mark, he has a decent amount of preload. I took mine off-road with the preload I did and it worked out very well. I also have no issues on the road.
Thanks for all of the info you've posted! Very helpful. I am currently running stock and contemplating suspension upgrades. I don't want to waste my time/money or make anything worse. So many people provide 80% advice.If you have Icon UCAs, then your system is different. You can check out the detailed install instructions, which talk about setting the live valve sensors using Icon's bracket system: https://images.iconfigurators.app/pdf/Icon_Dynamics/I98562DJ_REVB.pdf
@amREADY I installed front and rear shocks, UCAs, rear leafs and bump stops myself. Import and shipping to Canada sucks. There just isn't much to be done about it though. I use USPS where possible, but for some of these items like the leafs, that wasn't possible.
I have been happy with my set up. I've mostly run medium on the shocks offroad, but for higher paced action the firm setting works really well. Soft is not much use for me.
I think lifting the front 2+ inches won't serve you well offroad, as I've stated above in earlier posts. Happy to discuss if you like.
Good luck
