Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford Raptor Suspension Discussion and Modification
2017 Suspension Refresh Kit
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Badgertits" data-source="post: 2092368" data-attributes="member: 31322"><p>Again- On a different vehicle my C5Z- the bushings for the upper/lower control arms where they attach to the frame are injection molded rubber of some sort (not sure on raptor would have to check) & can’t really be pressed out cleanly but they’re also tucked in tight to the body & on a car like a vette that sees no salt/snow limited rain & sits indoors a lot there’s not a lot of reason for those bushings to degrade- they were/are still quite supple so I left em in place & instead media blasted the arms & gave em a black epoxy coating, pressed in new moog greaseable ball joints, replaced front/rear sway bars + bushing + end links, the inner/outer tie rods/toe links all 4 corners, the steering rack, the wheel bearings, the steering rack bushing (yep), the motor mounts (poly), swapped the thin stamped steel tunnel plate for a thick billet aluminum one etc etc etc </p><p></p><p>You could go to similar lengths w/ a Raptor but it ain’t a collector car (unless you want it to be I guess) & isn’t old enough to have all the aftermarket part options I’m guessing (maybe wrong)</p><p></p><p>I don’t think you need to tho- I think the front top hats/shock buckets or whatever you call em could be replaced, the shocks, the leafs, the coil springs, the tie rods, the swaybar bushings/links, & IF the a-arm bushings look ok & IF you can source correct sized ball joints doing that instead of replacing A-arms would save $$$$….but there are also better aftermarket control arms available too</p><p></p><p>It just depends on how “nuts” you wanna get</p></blockquote><p></p>
[QUOTE="Badgertits, post: 2092368, member: 31322"] Again- On a different vehicle my C5Z- the bushings for the upper/lower control arms where they attach to the frame are injection molded rubber of some sort (not sure on raptor would have to check) & can’t really be pressed out cleanly but they’re also tucked in tight to the body & on a car like a vette that sees no salt/snow limited rain & sits indoors a lot there’s not a lot of reason for those bushings to degrade- they were/are still quite supple so I left em in place & instead media blasted the arms & gave em a black epoxy coating, pressed in new moog greaseable ball joints, replaced front/rear sway bars + bushing + end links, the inner/outer tie rods/toe links all 4 corners, the steering rack, the wheel bearings, the steering rack bushing (yep), the motor mounts (poly), swapped the thin stamped steel tunnel plate for a thick billet aluminum one etc etc etc You could go to similar lengths w/ a Raptor but it ain’t a collector car (unless you want it to be I guess) & isn’t old enough to have all the aftermarket part options I’m guessing (maybe wrong) I don’t think you need to tho- I think the front top hats/shock buckets or whatever you call em could be replaced, the shocks, the leafs, the coil springs, the tie rods, the swaybar bushings/links, & IF the a-arm bushings look ok & IF you can source correct sized ball joints doing that instead of replacing A-arms would save $$$$….but there are also better aftermarket control arms available too It just depends on how “nuts” you wanna get [/QUOTE]
Insert quotes…
Verification
Post reply
Staff online
Big Blue
Administrator
Members online
MiRhodes
ActionJaxon
Roush2568
RaptorFun
GG17
stiknrun
Big Blue
mdamon
Sharpie69
SRTConvert
goblues38
Cookie
Todd Turbo S
blcws6
Mike2011
nealhoney
MrBuddha
elpechedepeche
Waterfowler41
drtibrd
John813
TYRCS
AlecWin
Bozz
GLT
Zeusmotorworks
mashtastic
MOTOR10
Mind Goblin
buford321
DDBama
NEOGARAGE
gtogsxr
Reaper308
Shane361
hardcoreKaren
Dain
Sage
abrown
DFS
mprice1234
Nick@Apollo-Optics
Jesse1983
Fender150
xturdfergusonx
KillTires
IHAVETWO
chris_tofu_r
Jmeo
GCATX
... and 41 more.
96,599
60,576
Brute
Forums
Accept
Learn more…
