2017 FORD RAPTOR AFE POWER SCORCHER GT MODULE - 77-43023
$499.00
The 2017 Ford Raptor aFe Power Scorcher GT Module will give you a huge increase in power. It includes high-quality case & wire harness with factory style connectors for an easy plug & play installation. For on-the-fly power adjustments there is a LED light switch. This performance module will increase turbo boost, vehicle performance, and throttle response.
This quick and easy plug & play SCORCHER GT module adds significant power by altering pressure sensor signals to increase turbo boost and to improve vehicle efficiency, power, and throttle response.
In testing, this Module tested at +44 HP and +65 ft. pounds of torque.
SCORCHER GT modules feature In-Cabin On-the-Fly power adjustment to accommodate any situation. This adjustment is controlled by via LED light switch with a button that can be easily mounted in any location in the cabin.
APPLICATION: 2017 FORD F-150 RAPTOR
https://www.southerncarparts.com/2017-ford-raptor-afe-power-scorcher-gt-module.html
$499.00
