2010 SCAB
EccentricRaptor
Midwest
Welcome! :D Pics please!! Or everyone else will claim you bought a Prius :p
Unfortunately, I don't have any suggestions for you. Hopefully someone else will - I'm new to the trucks. I'm at the technical level of just taking it to your dealer and explaining what it's doing. The off-road suspension is a bit springy on them, but what you're explaining seems odd. Mine slightly nose dives when braking harsher and the rear slightly dips on rapid initial acceleration.
CoronaRaptor
CANADA
Welcome to the place, are you thinking your rear brakes are locking up a bit, such as the rear calipers are seizing or are you experiencing a clunk in the back. More specific if you could and post a pic of your baby.
CoronaRaptor
CANADA
Remove your driveshaft and use the Ford lube on the yoke, check your u-joints as @MurderedOutSVT mentioned. If that doesn't solve the problem, then you may need some rear end work. There is also this stupid vibration abosrber on top of the frame on the drivers side rear that by now is probably slopping around. It looks like a brick of steel that is loose up there.
