GEN 2 20 inch Rigid Lights
mgkdds
AR
Sorry if this has been covered before but for the last 2 weeks ive been searching with no good answer.
I was a previous Gen 1 owner and taking delivery of my new Gen 2 in the coming weeks. My rigid lights have been collecting dust in my attic.
I have the Gen 1 fog kit with the 4 D2 midnight editions and a amber 20 inch in the gen 1 lower grill. Ive found that all I really need is two more lights and the new fog bracket. Which is awesome.
My question is why cant you run the 20 inch rigid in the lower grill section on the Gen 2.
Is it a fit issue or because of the inter-cooler located there.
Again sorry if this has been covered but I couldnt find a clear answer.
Thanks guys and yes as soon as i get it I will post a picture to prove its not a Prius!
4x4TruckLEDs.com
You probably could to be honest, for the Rigid Bar. You'll just need to make your own mounts somehow. Baja makes a 10" kit because it's bolt on. The 20" will JUST FIT I believe from what I've seen folks do. No bolt on kit for it though.
For your fogs, yes you can re-use your Rigid and just get some new brackets. You can check out our SPP Triple Fog Light Brackets here. ROCK SOLID brackets, made here in the USA by a guy who sells Roush Trucks and Raptors all day long (so he know what he's doing). Adjustable brackets and we also have a completely plug and play harness for the D-Series lights... available here: http://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-brackets/
We also have a whole bunch of Rigid D-Series for your liking you can choose from (a set of SAE might work nicely for you as the 3rd pair):
Rigid SAE: http://www.4x4truckleds.com/rigid-industries-d-series-sae-fog-lights-pair/
Rigid D-Series: http://www.4x4truckleds.com/led-auxiliary-lights/rigid-industries/d-series-pro/d-series-pro/
Rigid D-Series Midnight: http://www.4x4truckleds.com/led-aux...s/d-series-pro/midnight-edition-d-series-pro/
