0mm offsets
banman12
Rochester, NY
Hey guys,
I know the Method's a lot of you guys are running are 17x8.5 0mm offset. I am looking at a 17 or 18x9 0mm offset, which compared to the methods would be about another 6mm of "poke". Do you guys think I will have any issues? Can anyone chime in with 9" wide wheels with low to 0 offsets? Thanks a lot guys, just wanna make sure I am making the right choice, I dont want to run into suspension issues from the setup.
banman12
banman12
Rochester, NY
20X9 0 offset and I do get a tiny rub, thats annoying enough I am making the itre shop order +18mm so I dont rub...
Thanks for the honest response. I had a feeling that extra poke might cause some rubbing. I will most likely go with the Methods since they are 8.5" 0mm offset. They seem to fit perfect.
