GEN 2 “Thud” sounds
MurderedOutSVT
Brodozin
The ATL
This might be a dumb question, but if it was the torque converter would I hear or feel it messing up driving around?
Neh, not dumb. I am by no means a transmission expert, just speaking on experience.
Calling @Old-Raptor-guy and @FordTechOne for expertise
I went to torque converter because thats the only rotating mass when you experience issues.
Torquing moving the mounts was the other movement I thought of.
Does it ever flutter shifting gears or have a hard/awkward shift?
WNCgen2
WNCgen2
North Carolina
In the month I’ve owned the truck I’ve had one harder than normal shift from 4-3. Other than that, it’s shifted just fine.
WNCgen2
WNCgen2
North Carolina
Tried to capture a video. Let the truck warm up and put it in drive with zero noises. The times I’ve noticed the noise was after driving around town after 10-15 minutes. Unfortunately I’m at work and can’t take it for a drive.
Old-Raptor-guy
USA
Sound like it is inside or outside the cab?
Never heard a torque converter makea thud noise, and it spins at engine RPM so it would be a pretty fast thud,thud,thud,thud. Fast like 10 times a second at idle (600÷60 sec = 10 times a second).
Need more info,
Is it just once randomly or once it starts is it pretty regular? If so how often(1 every couple secs or 1 every couple minutes).
WNCgen2
WNCgen2
North Carolina
Need more info,
Sounds like it’s outside the cab while I’m in the driver seat. Seams like the truck has to be driven a little and then once I stop (at a drive through) I hear it off an on. Sometimes quiet, sometimes a little louder. I’m completely stumped. A few noises (5-10) then a few seconds of silence. Then some more noise.
