Hornblasters Train Horn Kits!!
NickPic83
Rockland County NY
yeah i had a kit on my last truck. i def miss them and everytime someone cuts me off or does something stupid im like, i wish i had my air horns!!
infinitereality
SLC IR/8
Louisiana
Not sure if you're talking about the compressor or horns, but I have my horns from the 240 kit on the skid plate. PERFECT fit around the oil filter hole too!
SilentShooter
Siesta Key, FL
I must add this to my mod list.. I had air horns in my Hummer and loved them. What was really nice is that they offered a bolt in kit that fit under the hood for a simple bolt in install. I do miss the Oh Shit look on peoples faces when they make me flip the switch.
CLAMUP
Here is a good location for the Nathan K3LA.
Yukon Joe
Trafford, PA
Need some help guys.
Who has wired their train horn to the stock horn with the supplied rocker kill switch?
I've followed the wire schematic but I can't get the train horn to sound off when I hit the wheel horn.
I had the train horn wired to ground and to the rocker switch. Switch to the stock horn wire under the dash (purple with green stripe). I know there are two of them. I'm using the one that when cut, the stock horn didn't work. So I'm pretty sure I have the correct horn wire.
After some time I've found that the horn wire under the dash is constantly hot (@ 12volts). So I moved the train horn ground to the battery positive terminal. Still couldn't get the train horn to sound off.
Suggestions? Thoughts?
Yukon Joe
www.RUNRAPTORRUN.com
