How do you get all the coolant out when changing anitfreeze
I changed out my antifreeze the other day but according to the manual the capacity of the system is 16 quarts. I was only able to get about 8 quarts out and that included starting the engine for a few minutes to see if the water pump would push more into the radiator to drain out. I waited for about 45 min. after opening the radiator drain plug until there was nothing else dripping out. When refilling the system I was also only able to pour in about 2 gal. of 50/50 coolant.
