2024 801a - Road to 37s
Ox3721
Arizona
Yeah, not only would the ride suffer tremendously, the F’s would probably add at least 20 lbs per corner.
jeffraptor
houston
You wont even come close to rubbing with 37" K02s on the stock wheels with no level. I ran that setup on my 2024 for a while and took the truck off-road with no problems.
I installed the Eibach 1" front level springs but next year I am going to swap them out for the Eibach pro kit or the Geiser kit.
GU3R086
GU3R086
Colorado
This would be my preferred method no doubt.
John813
PSL/Jupiter
Not all 37x12.5x17 tires are the same.
I'm running AT3 XLTs. They are not as wide as the Nitto Ridge Grapplers in the same size.
Below picture shows the difference.
https://www.fordraptorforum.com/thr...aptor-today-gen2.59415/page-1241#post-2075110
A 37 C load KO2 is also narrower than some of the other 37" out there.
IIRC, closer to stock offset is better, as the further in the wheel/tire is, it keeps it away from the fender at full tuck.
taquitos
Seattle
Ford didn’t decrease travel on the 37 trucks for no reason. If you truly bottom it out, clearance is tight as is. This post here shows exactly why https://www.fordraptorforum.com/threads/installed-37s-on-gen3-35-raptor-no-issues.87003/post-2017518
A static clearance test isn’t perfect either though. When you see those videos where it looks like the bumper is bouncing around a lot (mostly people jumping), it’s not the bumper moving, it’s the whole body. Real world wheel clearance can be even lower than static clearance.
MORaptor1
SW Missouri
Factory 37’s (0 offset wheels) are kinda skinny looking. Truck sure does ride well however. Super cushy.
shigman
Cypress, TX
They are kinda skinny....lol Overall keeping the weight down and making the tire easier to tuck sure has its advantages.
GU3R086
GU3R086
Colorado
What’s making you want to swap springs if nothing rubs?
Thanks for the info!!
GU3R086
GU3R086
Colorado
Yea this is actually my worry. Prob would keep my OE wheels or closer to OE offset if I bump up.
Good things to ponder here.
96,796
60,771
cristiansthee1
