Sunroof Rattle
Andrewalker7
Hello everyone,
2019 here, and my sunroof has an obnoxious rattle/rub every time I'm off road... and on horribly maintained "paved" roads alike.
Full assembly is functioning, and no amount of frequent operation seems to fix it. Noises are only when fully closed, thus far.
The dealer suggests it just needed lubricating about two months' back... so they did that (just some grease in the tracks, really), and it was fixed for about 3-4 days.
It's back now, even with grease still everywhere.
Anybody have similar issues/noises, and have a fix?
Thanks in advance.
Topher
Dallas
Just had this done, took it to Ford and they cleaned and lubed it all. Now its quite again.
gopher870
Utopia
  • Vista Roof TSB (2).pdf
M_NorthRaptor
British Columbia, Canada
It's the dust and grit getting between the seal and the cab. I used to get it on both my 18 and and now my 19 raptor. I take a bit of isopropyl and take a non sharp narrow tool (I used an interior panel removal tool) with a rag and have to work your way around the whole sunroof (carefully). You will be shocked at how much grit gets in there. Afterwards I used a rubber condition and sprayed all around the seal and let sit for a bit, may need a couple applications. Noises instantly went away.
Hope this helps. It's a common issue
K223
Florida
JefferyGT
Vantucky
Literally just got done dealing with this, was driving me nuts! I actually did it around 7k miles as a maintenance item as it wasn't rattling. Currently at 14k miles and the rattling was driving me insane. Followed the TSB and used the Krytox , rattles are gone.
That Krytox stuff is more valuable per ounce than your Mistress' Truffle Butter
