TORSEN Front Differential in the 2012 Raptor
BigJ
From the order guide:
TORSEN® Front Differential
• Standard on the SVT Raptor, the TORSEN (torquesensing)
differential uses a parallel helical gear
system to sense torque differences between the
front axles/wheels and provides maximum torque to
the wheel with the most traction
• The differential continuously manages power
delivery between the front axles/wheels helping to
maximize available traction over a wide variety of
surface conditions
• By providing a better balance of power, not only
between the front wheels but between the front and
the electronic locking differential-controlled rear
wheels as well, overall vehicle acceleration, handling
and traction are significantly improved
• Includes aluminum differential cover
Can you experts do a little translating for us amateurs? Specifically, why do you think Ford went to this diff, vs keeping the open design of the '10/11? If I understand correctly, a TORSEN is TORque SENsing, meaning it won't lock on demand; is that right? Do you think this is a good move on Ford's part? Why/why not? Any other info?
The Tank
McMurdo Station Antarctica
Torsen diffs are awesome. In some racing series a Torsen diff is illegal because it gives you a very noticeable advantage going through and out the corners. This is are very good choice for Ford instead of a full e-locking diff. It does everything for you and doesn't require driver input. This is part of the reason why the BOSS302 and BOSS302 LS are so much faster then the M3. I will need to do research to see which is better for me but I think I will be switching to a TORSEN front diff instead of an e-locker.
NoCaDiver
Thanks Tank for the brief.
I apparently need to watch the differential video again...from the 1960's.
NoCaDiver
^^ Yeah, I was kinda referring to my differential issues, not knowing if a Torsen is any good or what the benefits are, and the video that was posted on here explaining the differential. Plus I don't Torsen was even out in the 60's. :nana:
BigJ
BigJ
Thanks Tank!
Any idea if this would be a drop in for us OG's? Any software concerns?
The Tank
Thanks Tank!
An 8.8 carrier is an 8.8 carrier so it should just drop in. I would suggest waiting until after the 2012s drop to make sure you get a Raptor front diff and not a Mustang rear diff. I don't think there would be a software problems
KaiserM715
Kaiser Söze
I am pumped that Ford is offering this. It shows more progression to off-road capability. Now all I need is a junkyard '12 Raptor....
treypal
Lord of the Raptors
Riviera TX
I have to say that I am not excited about this. More stuff to break, more strain on CVs, etc... I rarely use 4x4 though, so I guess it wouldn't really affect me anyhow.
95,983
59,706
onthony
Latest posts
