BigJ
- Joined
- Aug 5, 2010
- Posts
- 5,448
- Reaction score
- 1,561
Someone please double check me. I've tried to break this out into a quick easy way to see what you've got going on given the various button presses and knob switchings
2H or 4H
= Stock shift points & Stock throttle map & Stock AdvanceTrac & Stock ABS
2H or 4H
+ AdvanceTrac single press
= Stock shift points & Stock throttle map & Street Sport AdvanceTrac & Street Sport ABS
2H or 4H
+ AdvanceTrac hold for 10 seconds
= Stock shift points & Stock throttle map & AdvanceTrac off & Street Sport ABS
2H or 4H
+ Off Road Mode
= Off Road shift points & Off Road throttle map & Stock AdvanceTrac & Stock ABS
2H or 4H
+ Off Road Mode
= Off Road shift points & Off Road throttle map & Off Road AdvanceTrac & Off Road ABS
2H or 4H
+ Off Road Mode
= Off Road shift points & Off Road throttle map & AdvanceTrac off & Off Road ABS
4L
= 4L shift points & 4L throttle map & Stock AdvanceTrac & Stock ABS
4L
= 4L shift points & 4L throttle map & Off Road AdvanceTrac & Off Road ABS
4L
= 4L shift points & 4L throttle map & AdvanceTrac off & Street Sport ABS
4L
+ Off Road Mode
4L
+ Off Road Mode
4L
+ Off Road Mode
= 4L shift points & 4L throttle map & AdvanceTrac off & Off Road ABS
*NOTE: Engaging or disengaging the Locker at the end of any of these sequences has no effect on the results, except to lock or unlock the rear differential.
*NOTE: Changing between 2H, 4H or 4L resets the AdvanceTrac and ABS modes to stock. Or to put it another way, "Changing Transfer Case Mode resets AdvanceTrac to key-on state"
2H or 4H
2H or 4H
2H or 4H
2H or 4H
+ Off Road Mode
2H or 4H
+ Off Road Mode
2H or 4H
+ Off Road Mode
4L
4L
4L
4L
+ Off Road Mode
4L
+ Off Road Mode
4L
+ Off Road Mode
