Billet Badges
- Joined
- Aug 31, 2010
- Posts
- 64
- Reaction score
- 6
The badges we make will come with 3M VHB (Very High Bond) adhesive and will stick on. The adhesive will be a lot more secure than the plastic clips. After you remove the factory oval, just clean the surface with rubbing alcohol and apply the badge. Just test fit the new oval on the bezel before you remove the adhesive and make sure it fits flush.
It has been brought to my attention that the the white plastic piece does need to be cut down for the replacement oval to mount flush. See picture below.
I have sold hundreds of ovals for F-150 trucks with back up cameras and this is the first time a customer has come forward and let me know that this modification needs to be made. This customer has a 2013 truck so it might be something new that Ford didn't have on the previous year trucks, but I am not sure. Please let me know if you needed to modify your bezel if you have an older model truck. Also if you did cut off the white plastic parts, what tips do you have to do so? I would think a Dremel tool with a cut off wheel would trim it off quick and clean.
If you do not want to modify the plastic bezel to mount the new billet aluminum oval that Billet Badges supplied, you can return it for a full refund. I do apologize for not having knowledge of the mounting modification.
