Raptor rattling riddle - experts wanted
BajaFred
Wondering if anyone has seen this or has ideas?
I think it sounds like a spray can rattle and you can feel it in the floorboard, steering wheel isn't shimmying beyond collateral damage from the rattle-induced vibrations
It's slightly different than the other thread as it happens at an exact moment - driving and accelerating "normally" rattles start right by 50mph, goes away IIRC after 53/55mph
If you get on it hard, the rattles don't happen
Can't find another speed band where it happens - tested up to 85mph
Rattling goes away either when you let off gas (rattles stop immediately) or if you keep driving, the rattles get progressively louder then abruptly stop above the speed range
Will not do it in park nor on a lift, which makes troubleshooting painful
IIRC happens in both 2H and 4A
http://www.youtube.com/watch?v=Wf_Kzea2vTA
Bullishone
No clue. Doesn't sound good though def take it to the dealer.
Hockster
My 45ft Bluewater Party
Winchester, Va
Very hard to diagnosis this from a video. It almost sounds like a loose heat shield. Is the performance the same?
B
BajaFred
She's at the dealer, didn't make it 50 miles away
They spent 6 hours on it today, nothing obvious is loose, not fluid/tire related
As for gears, it's tricky since if you're accelerating normally, you'll hit the same gear at the same speeds but didn't think of locking out gears one by one
Performance feels fine rattling aside, get on her during the rattle and she moves just as fast out of it, no apparent lag or hesitation
Checked wastegate and looked for any cables or wires that could be smacking the chassis
The head scratcher is how damn consistent it is starts as you near 50mph so feels like a gear or a resonant/harmonics issue
Built a few weeks ago
B
BajaFred
Dealer suspects vacuum harness for the front four-wheel drive activation
Usually its the IWE that goes bad, this would be the first time he's seen the harness as the issue
He's very confident so am hoping it's a done deal
BF, do you have a go pro?
maybe hood mount it or get it somewhere outside to see if you can pick up a rattle outside. This sounds like a cab rattle to me but if you can feel it in the floorboards, and the harmonics match the rattle and it only happens while you’re moving it has to be related to the drive train. If it’s 2h / 4A consistent, I’d be inclined to look from the trans rearward. It almost sounds like a dying cat(alytic converter).
I’d suggest engaging a decent go pro externally to see if you can pick up a rattle with more audio clues. I’ve got one on my ZX10r that picks up a mysterious bodywork rattle on video, that is not in the audio sound track on the bike. It happens about 4-4.5k but I’ll be damned if I can track it down. I can only hear it on the GoPro !
Good luck with it.
