is that the stock tire on the left, looks like you're losing alot of tread width going to that 36.3 bfg "37"
Oooo....exactly what I wanted to see! I've been thinking about replacing my 35/12.50/17 Toyo MTs with a set of 37/12.50/17 BFG ATs....mainly for increased wear. As much as I've liked the Toyos, I've only gotten about 28 000 miles out of them even with religiously maintaining proper tire pressure and rotation.
Anyways, I was concerned with rubbing as I'm running mid-perch with 17 X 8.5" ProComp wheels with a 0 offset (4.75" backspace) which I believe are the same wheel specs as the Methods(?) you are using....if not Methods, they do seem to have some negative offset similar to my ProComps! Are you have any rubbing issues with day to day use and mild 'wheeling?
Thanks!
Damn does that look sick. You get any kind of rub on the front when jumping or hitting a bump when wheels turned to the side. Want those projects but just too much money when they suck for the street.
