Contact me for the best available pricing on Smitty Bilt or Warn Whiches.
Some nice Winches for you to look at.
9.5XP-S Self-Recovery Winch
Part Number: WAR87310
Rated Line Pull: = 9500 lbs.
Voltage: = 12V
Motor: = 6.0 HP
Remote Control: = Remote switch, 12 ft. lead
Gear Ratio: = 156.1
Size: = 22.7 in. x 6.3 in. x 7.7 in.
Weight: = 87 lbs.
Synthetic Rope = 100 ft. of 3/8 in.
Fairlead = Hawse
Reg. Price: $1,549.00
PM me for the best available pricing.
X2O Comp Series, 10,000 lb. Amphibious Winch
Part Number: S/B98310
Rated Line Pull: 10000 Lbs single-line
Gear Train: 3-Stage Planetary
Clutch: Rotating Ring Gear
Drum Size: Diameter 2.5 (63.5mm), Length 8.75 (222mm)
Battery Leads: 25mm
Mounting bolt pattern: 10 x 4.50
Motor: 5.5hp Series Wound
Control: Remote Switch, 12' (3.7m) lead
Gear Ratio: 218:1
Brake: Automatic In-The-Drum
Synthetic Rope:94'of 5/16"
Finish: Black
Weight:88 lbs
Reg. Price: $849.99
PM me for the best available price.
Please contact me for the best pricing on a specific Winch.
Voltage: = 12V
Motor: = 6.0 HP
Gear Ratio: = 156.1
Weight: = 87 lbs.
Fairlead = Hawse
Battery Leads: 25mm
Gear Ratio: 218:1
Finish: Black
Weight:88 lbs
Reg. Price: $849.99
