PLEASE NOTE: This image does not show the 6-lug Raptor Rotors.
R1Concepts "Premium" - Double Cross-Drilled & Slotted Brake Rotors
R1Concepts PREMIUM SERIES BRAKE DISC
WITH BLACK MILITARY GRADE E-COATED HUB FOR INCREASED LONGEVITY
R1Concepts Premium Series Cross Drilled and Slotted Rotors offer outstanding stopping power and performance as well as dependable longevity.
Product Description :
- Cross-Drilled and Slotted Design
- Drilled holes provide maximum air circulation for increased cooling
- Holes are countersunk which reduces heat build up
- Exclusive R1 Concepts Diamond Slot increase brake pads bite
- Diamond Tip use as indicator for brake rotor wear
- Black E-Coating Gives Long Lasting Corrosion Protection
- High strength cast iron discs
- Direct Fit OEM Replacement Brake Rotor
- Double disc ground finish reduces rotor vibration
- Meet Or Exceed OEM Standards For Excellence
- Mill balanced brake rotors ensures long lasting durability
- Superior Machined Surfaces That Provide Smoother And Quieter Stops And Longer Brake Pad Life
Note: R1Concepts Premium brake rotors are machined using a G3500 grade Carbon Metallic compound which is much stronger than other offered rotors on the market today since the vast majority of them are cast from G3000 grade cast iron. Stronger, longer lasting and offering better cooling properties than cast iron, the Premier series rotors are by far the better choice for all Raptor Owners.
CLICK HERE TO BROWSE FORD RAPTOR SVT PACKAGES
