We now have pictures of these MOUNTED!
Upper Shock Mounts aka "Duck Plates":
This rear upper shock mount reinforcement bracket or "Duck Plate" helps reinforce the factory shock mount from twisting or tearing loose.
These work even if you have aftermarket shocks (ICON, Fox, ect....)
This Upper Shock Mount is quick & simple for anyone to install. The bracket can be bolted or welded on. Hardware is included.
The cost for a pair of these run $199.99. You can order these here.
Lower Shock Reinforcement Plates:
Our lower shock mount reinforcement plates help protect that factory shock mount from being bent or tearing loose when traveling in a rougher terrain
These work even in you have after market shocks as well (ICON, Fox, ect...)
From what i can see, these should not interfere with bumpstop systems as well.
The cost for a pair of these run $249.00 You can order these here.
You can purchase these as a pair (Both upper and lower mounts) for $400.00 and save $49.99! Please call (909)-599-2228 to order these together!
Pictures of Upper Shock Mounts:
Pictures of Lower Shock Mounts:
![null_zps033e789c[1].jpg](/proxy.php?image=http%3A%2F%2Flge-ctsmotorsports.com%2Fimages%2Fstories%2Fvirtuemart%2Fproduct%2Fnull_zps033e789c%5B1%5D.jpg&hash=d855b3d9c48a3877477bb71b6da66c40)
