Volant has a new 3" single exit system for the 6.2L Raptor - part # 54387. I decided to try it out because my JBA side exit system had seen better days.
![IMAG0806.jpg IMAG0806.jpg](https://www.fordraptorforum.com/data/attachments/49/49549-4fc28c0928d37b9c755377498a61525c.jpg)
Since I no longer have an intact resonator pipe, I also got the Corsa Resonator delete pipe to fill the void and bring the noise a little more.
![IMAG0807.jpg IMAG0807.jpg](https://www.fordraptorforum.com/data/attachments/49/49550-fded9fdbe7bfa955fe94eef419e89f3f.jpg)
This kit is priced in the $649 range, and the resonator delete pipe can be had for around $200. *** RESONATOR DELETE PIPE P/N FOR SUPERCAB 133' WB IS 14757. SUPERCREW 144" WB IS 14758 *** EXHAUST IS SAME FOR BOTH WHEEL BASES ***
![IMAG0810.jpg IMAG0810.jpg](https://www.fordraptorforum.com/data/attachments/49/49551-97322ad8825b9fe7e01847107dbbe05d.jpg)
I must say that I am pleasantly surprised by the sound. To be honest I was not expecting it to sound as good as it does. On top of that, it's whisper quiet at cruising with not the slightest hint of drone. When you get on it, all hell breaks loose.
Speaking in terms of the Corsa brand, this Volant system would be most comparable to the Corsa dB line from a price standpoint.
It's 400 series stainless, uses the cheaper clamps and comes with a single wall slash cut tip. That's basically your price difference right there. The muffler internals are also different than the Corsa RSC mufflers.
![IMAG0811.jpg IMAG0811.jpg](https://www.fordraptorforum.com/data/attachments/49/49552-6a4767ede2d6a2debb33781a34bb27b5.jpg)
![IMAG0812.jpg IMAG0812.jpg](https://www.fordraptorforum.com/data/attachments/49/49553-471fdda2264f01d10d201b6f0e1664a1.jpg)
The install was fairly straightforward, just a little love with a hammer on one of the hangers and everything lined up perfectly. Unfortunately this system does not clear the tension rod on my ICON bump kit, so I simply removed the rod for now since it's not entirely necessary anyway.
I sealed all of the connections with copper RTV, which I recommend doing with any slip fit connections.
![IMAG0813.jpg IMAG0813.jpg](https://www.fordraptorforum.com/data/attachments/49/49554-d109f0da654113fd921ff22f0bbd840b.jpg)
Shiny!
![IMAG0818.jpg IMAG0818.jpg](https://www.fordraptorforum.com/data/attachments/49/49555-e500a33a3164210aad353570bb245f26.jpg)
Now, for the sound. Holy hell. There's something to be said for a single exit system. It's hard to describe, but basically the entire tone changes. The exhaust sound is more concentrated, if that makes sense.
I have heard almost every aftermarket exhaust offering for the Raptor and I can't really compare this Volant system to anything else. It honestly rivals Raptors I have heard with long tube headers. It has a loud brap to it that you can feel in your chest. Almost like a Harley with straight pipes except not quite that loud. Keep in mind the resonator delete pipe helps the cause, but I'd imagine this system would sound great with a stock resonator as well.
The sound in the video is pretty true if you have decent computer speakers. Have a listen for yourselves and enjoy:
Ford Raptor Volant 54387 Exhaust - with Corsa Resontor Delete - YouTube
Shiny!
